Dear Autodesk,
At this moment, when more company’s then one needs to solve an issue you need to make separate issues, even though it is about the same thing.
It would be great if you can assign more than one company to an issue, since in many cases for one issue more than one company needs to work on it to solve it.
It would be even better if you can assign more than one company and put them in order. So first company 1 needs to say: ‘solved’, then company 2 needs to say ‘solved’, etc. And in that order, the entire issue is solved.
P.S.
This idea comes from a couple of clients that made the transition to BIM360 field but are missing some simple adjustments in comparison to other similar programs.
