Allow Deletion/Hidding of Packages BIM360 Design Collaboration
As a project manager I want to be able to delete or at least hide packages from the time line in BIM360 Design Collaboration.
Related Forum Topic: https://forums.autodesk.com/t5/forums/replypage/board-id/6011/message-id/772
12 Comments
Martyn,
For me (an employee of an Autodesk VAR) demonstrating Design Collaboration in a Demo/Training project, this would be a great reset feature. I completely agree with you regarding the destruction of historical progress in a low-trust consumer project (https://forums.autodesk.com/t5/bim-360-document-management/delete-a-project/td-p/6872891) but, it would be a nice feature to have in a Demo/Training project. It becomes rather annoying to create a new project and go through the motions in order to reach a point in time to demonstrate the process. Would it be possible to make a toggle in the Profile of the Project that only a Project Admin could change? This would also provide the Admin with the ability to delete Teams in the Design Collaboration Service which in turn removes the Project Files folders.
martyn_messerli
Hi Bill,
thanks for your feedback. I'm not aware of any plans to do so.
Sorry for the bad news. I'll forward your request to our Product Owner.
Martyn
PS: Since you can't really delete files from Docs, how would you handle that use case?
How about if it can be deleted within a given time frame?  Say no more than 15 to 30 minutes after sharing? I could even accept 10 minutes since we normally can see if we did not share everything or overshared.
Make this possible TODAY please.
stephen.tritchler
Please give project administrators the choice to decide for themselves what is appropriate to delete and not to delete. It is not really appropriate for Autodesk to be making this decision for us and force us into the way you believe we should work.
StevenMar
1)  Allow only the original poster/Administrators to remove packages.
2)  Set up a toggle under the Project Admin module that allows/disallows the deletion of packages.
My problem is that I've made a mistake in the drawing that I packaged and now I corrected it and don't want users to use the wrong package...
dvisani
What if you accidentally post a package?  For example, something confidential,  misleading, or just wrong?  Is the only solution to just delete the entire project and restart?  The ability to either remove or hide packages (with permissions, etc) would be greatly appreciated.
breidecs
Administrators and Original posters of the package/s should be allowed to remove these if required. This is an issue I have come across on several projects. Also it gets confusing if someone new comes along, publishes the model and then shares the wrong package - and this could easily happen and also potentially cost someone thousands of dollars.
Chad-Smith
I am mostly on Autodesk's side on this one. The ability to remove/delete something that someone may have already seen, downloaded, and have already made decisions on can have legal consequences. The ability for the account host to manipulate data after the fact, could also instil doubt with users, which may lead to loss of use.
However, I also understand the concerns raised, and I do believe that Autodesk could do something to help 'clean up' accidental packages. In the same way that other data can be 'voided', maybe packages require something similar? Voided packages could be a different icon on the swim lane (maybe a triangle) and maybe they could be a fainter tone so they are not so prominent. Also, a Filter to hide them, with them being hidden by default.
When a package is voided, a reason would also have to be provided.
I'm also fine with the contents of the voided package being hidden/locked. But, the package metadata (name, date, description, void reason, etc) would have to remain visible. This keeps the record on the swim lane intact should someone have already viewed, downloaded, or made decisions on the subsequently voided package.
If the packaged has not been viewed by anyone, then I am happy the package can be deleted. But once it has been viewed, then deletion should not be possible.
With the above in place, I would be comfortable that anyone with Edit (Share) permission to be able to void packages.
CCanonaco
Everyone sync'd, I mistakenly published and shared a package without checking the set's sheets.
Early next morning, I examined the sheets which revealed a jpg, let's call it unneeded content, I immediately tried to delete the package to no prevail, so I removed all but admin's access.
Weeks later, Autodesk continues to advise to delete the entire team and start a new one.
All project history lost... unless:
I could retrieve and upload to a new team, each version of each model, each links, etc., Publish/Share, repeat, repeat, repeat, repeat, repeat, repeat...
I would rather push a button to delete, and face the consequences, which can all be Disclaimed with an Are you sure button.
shahrzad_adibi
Observer
I have shared the wrong model in the package which was so confidential, can any body please help me ???
martyn_messerli
@shahrzad_adibi my apologies, unfortunately there is no way to revert this action.
