View older versions
View older versions
It seems that BIM 360 (both web and app) is showing only the latest version of a drawing / document. Customers often need to review the previous versions with the comments and markups on them and then see how the latest version has addressed them.
I noticed that older version source file can be downloaded in Web version, but not convenient to quickly review it.
Siva
7 Comments
joan_allen
BIM 360 Docs provides access to older versions.  On the web, you can select the "history" tab on the left and you will see all of the versions.  Select a specific version to view from there.
In addition, you can compare versions in BIM 360 using the compare tool.  For more information, please refer to the Release Notes here:  http://blogs.autodesk.com/bim360-release-notes/2018/04/27/bim-360-docs-update-april-25-2018/
Best Regards,
Joan Allen
Autodesk BIM 360
Siva_T
Thanks Joan. That helps.
I could also find similar in the IPAD app for BIM 360 Docs, however not in the BIM 360 app.
Siva
jwaddell
Is there any update on this for the BIM360 app?  We really need to be able to see older versions of the documents from the app.
Jason
It would be extremely helpful to be able to view versions in the BIM 360 app similar to the way it is available on the website.
brianking2519
The ability to view versions on an iOS or Android is a must!!!  Is there a time frame for this on the road map?  I am almost positive that this functionality existed in the old BIM 360 Docs app; but I could be wrong.
jerry.jeldness
Any update on this issue for the mobile versions? Many of our projects have requirements to be able to refer to older versions of the same drawings. The overall functionality of the Android version is disappointingly bare-bones across the board, but not being able to compare or view older versions is a must-have.
twellins
Nearing XMAS 2021 and no idea if this is even being considered by Autodesk.  Can you at least say YES or NO?  Who is monitoring these support pages as it feels like we are literally talking to a brick wall.
Our site team are 100% dependant on the iOS app to look and feel similar to the Desktop Version.  Every corner we turn we are hindered by the level of accessibility with this app.  This includes Version Comparing and Model Properties!!
