Dear Autodesk,
At this moment there are checklists available in the Field management module, which are designed for use in the field too for example check quality during the construction.
But in an earlier place and also later on the timeline of a project you want to use checklists for different purposes. At this moment we can misusage checklists in Field management for that, but since they are not directly linked to a model. Or it will create a mess in your field checklists.
My proposal would be adding checklists to document management, design and model coordination also. Where you can use checklists for document coordination and quality. And use checklists for model quality and checking if everything is according to the BIM guidelines.
Best regards,
Josha van Reij
