ACC // Markup functionality within the Takeoff module
Provide Markup functionality within the Takeoff module on ACC:
  • Currently you can only add Markup’s in the Docs Module
  • If you now publish a PDF drawing (with markup’s) from Files to Takeoff Sheets & Models, the Markup’s are not transferred
  • It is currently not possible to make Markup’s on Sheets in the Takeoff module itself
To have the Markup functionality available inside the Takeoff module on ACC would be a great benefit when working as a team with multiple people within the Takeoff module.
1 Comment
Chad-Smith
This, unfortunately, is a symptom of the fragmented nature of ACC. The hard-lined separation between the design and build stages, with separate container stores, doesn't create an efficient flow of data. Which is ironic for a platform that promotes centralisation and removing duplication.
A large part of this problem is the lack of 'Sheets' in Docs. I have written a more ambitious Idea regarding the improvement of the design stage, to then more efficiently allow data (such as markups) to flow into the build stage.
It's time to consolidate Docs + Design Collaboration + Model Coordination
I would prefer to see the core issue resolve, i.e. have Sheet in Docs, rather than a feature duplication to band-aid elsewhere.
Technology Administrators
