ACC // Allow Locations to be Progress Tracked
In ACC there are three features that currently operate relatively independently, but actually need to be connected.
Locations
Defined in the project admin, locations are referenced in other features such as Issues, etc.
Locations also have a QR Code so they can be quickly recalled onsite using the mobile app QR Code scanning.
But locations, being predominantly an admin setting, cannot be directly accessed by other members, and therefore remains rather unintelligent and underutilised.
Photos
The Photo library is a great resource where photos can be referenced to a Location.
But when a photo is assigned a location, it is not added as a reference in the admin Locations.
From a workflow perspective, site users are unlikely to capture photos and then later assign all the locations. This is a two-step workflow that should be avoided.
Progress Tracking
The newer progress tracking functionality (in Assets) can be used to create a 'Locations' category, against which location assets can be created. This is great for attaching references like progress photos.
But no-one will want to duplicate, and then manage all the duplicate admin Locations over in the Assets list.
The Idea
We can see from the above that there are numerous features to help track 'Location' progress, but they don't work together to form a complete workflow.
I have two requests:
  1. Expose the admin Locations to the member-facing UI, so that members can access all references that are attached to Locations. e.g. I want to find all information pertaining to an office.
  2. Expose the admin Locations to the Assets module, so that all the asset Settings can be applied. This will allow a Location to be progress tracked.
With the above two requests, a user can:
  1. Walk into a building location, and using the mobile app scan a QR Code to access the location's data.
  2. Raise new issues for that location, or view existing issues. Likewise for other references like forms, etc.
  3. And for the Location itself, track its progress using a Status Set, and capture photos. The location becomes attached to a photo for filtering in the Photo library.
    I would even argue that when viewing each Location, it should have its own mini Photo Library, so that the user can find all referenced photos on the asset without having to change over to the Photo Library.
I'm not a huge fan of using the Assets module for seudo-location management. Hence, having a dedicated tab on the UI for Locations makes more sense.
Why this Idea?
Due to the manual and laborious nature of the Progress Tracking feature of adding asset markups to sheets, it is highly unlikely this feature will be used. But the location's Status and Photos still need to be tracked.
By adding the above two features, other than defining Locations, there is no other setup that needs to be done to get a decent level of functionality.
4 Comments
S-SUTTER
This is a great idea Chad.   To add to this, if the user can define locations or location areas using the markup tools as you can today when defining assets in the Sheet -- this would enable "locations" to be easily defined/set up.   Permission controls should be used on who can define locations and who can update locations.
Furthermore having location "categories" would allow a grouping of like types of locations for reporting.   For example, in the beta version of Progress tracking we were defining inspection areas of our buildings.  These are defined in advance and then our Foreman/QC team changes the "status" as they do their inspection.   Issues are created if needed based upon that inspection location.      The planned GA version of progress tracking that is tightly coupled with assets won't work for us as what we want to track is not an asset but a location point.   I don't want to mix location points with one of our assets  as the two are very different for us.
tkeyser5
It would be handy if the location data could be pulled from the room data in the revit model.
clint.davisB6LG8
We need the locations to be pulled from the revit models as well.
Chris_Baze
@tkeyser5 @clint.davisB6LG8 just making sure you're aware that importing ACC locations from Revit is now possible https://help.autodesk.com/view/DOCS/ENU/?guid=Add_Import_Export_Locations#import-locations-from-revi...
