Product: BIM 360 Field
360 Module: Issues>Add/Edit Issue>Attachments>Add File/Library
Function: View Sharing from 360 Glue/Navisworks to 360 Field Issues
Statement: BIM Coordinators identify and filter clashes for later review by creating views in the 360 Glue and Navisworks platforms. From there, these clash views become issue items to discuss during meetings. Currently there is a way to track these clash issues within 360 Field, but it requires a very manual and time-consuming process of taking a screenshot or exporting of the view in 360 Glue/Navis and then re-naming and uploading as an attachment into the 360 Field Clash Issue item.
Requested Feature: Make these Clash Views generated in 360 Glue/Navis easier to associate with an Issue in 360 Field. Imagine being able to share your views from 360 Glue/Navis directly to the 360 Field Library. When you go to add an issue, navigate to the attachments tab, click add from Library and select the clash view image. Or, better still, enable an Issue to be generated directly from the View created in 360 Glue/Navis which can then be exported back into 360 Field.
