BIM 360 API Forum
Welcome to Autodesk’s BIM 360 API Forums. Share your knowledge, ask questions, and explore popular BIM 360 API topics.
Hyperlink Creation in BIM360 Field API?
4 REPLIES 4
570 Views, 4 Replies
Is there a way to create, revise, or query for BIM 360 Field Hyperlinks on a document?
4 REPLIES 4
mikako_harada
mikako_harada
Hi dbower,
Could you describe what you wish to do in more detail?  Maybe adding a screenshot of UI might help understand your question better.
Thank you for your cooperation.
Mikako Harada
Developer Technical Services
Hi dbower,
Mikako Harada
in reply to: mikako_harada
We would like to be able to define a link between two documents so that
a user could quickly navigate between the two. For example to go from a
floorplan to a section/detail/elevation.
The documentation says that Hyperlinking is supported between document,
but there does not seem to be a REST API call to establish the links.
I hope that helps....
Doug
Doug
mikako_harada
mikako_harada
Hi Doug,
Are you trying to add a markup link under library?  e.g.,
http://forums.autodesk.com/t5/bim-360-ideastation/hyperlinking-views-with-bim-360-field/idi-p/553154...
If so, markup is not supported, yet.
Mikako Harada
Hi Doug,
Mikako Harada
brodericksonpriddy7
brodericksonpriddy7
Community Visitor
Community Visitor
The BIM 360 Cost Management API (beta) provides access to the data stored in the BIM 360 Cost Management module. It allows you to manage cost and budget changes to your projects, such as accessing budget, contract, and change order information.
Open the main Revit file from BIM 360 and, [from] the Manage Tab > Manage Project panel (Manage Links), reload the link from the cloud location. Save the file, sync with central and publish.
Open your design or PDF file.
Click Add New Hyperlink.
Click and drag to select where to add the link.
In the dialog box, navigate to a folder and then select a document to link to.
Click Open to save the hyperlink.
