BIM 360 API Forum
Welcome to Autodesk’s BIM 360 API Forums. Share your knowledge, ask questions, and explore popular BIM 360 API topics.
How to use a feature file without touching shaswat?
1 REPLY 1
243 Views, 1 Reply
I want to create a complete login feature file and write its unit tests.
And I could run that unit tests, whenever I want.
After, I want to create another feature file (let's call it filling a form) and write its unit test.
But in my case, only logged-in users can fill out that form.
So I want to use the login feature file inside the filling form feature file.
Of course, both feature files must be complete and separate from each other, and I could run them simultaneously.
1 REPLY 1
mikako_harada
Is this BIM 360 API question?  This forum is for BIM 360 specific questions.
If you are using 3-legged authentication method, limiting to a specific user is as designed.
Some API call allows you to use 2-legged authentication although not all. For the part 2-legged is available, you may use it.
If you are trying to automate login process for your automated test, what you can do is to login as a user for the first time, then use refresh token for subsequence calls. For information about refresh token, you may refer to these posts:
https://forge.autodesk.com/blog/more-about-refresh-token
https://forge.autodesk.com/blog/about-refresh-token
Mikako Harada
Developer Technical Services
