BIM 360 API Forum
Welcome to Autodesk’s BIM 360 API Forums. Share your knowledge, ask questions, and explore popular BIM 360 API topics.
Data management API 403 Error: This user could not be authenticated
3 REPLIES 3
409 Views, 3 Replies
Hi All,
I am writing a python script that automates the process of getting drawing files from a project. Currently I am able to access but hub, list of projects and folders through the script. However, whenever I try to search the folder for all drawing files I get a 403 Error saying the users could not be authenticated.
I am using 2 legged authentication to get the access token. I added data:search to the scope as required by the api but still get the same error. I have search everywhere online and nothing seems to work. Please is there anyone that can help.
I have attached the access token  function, the search function and an image of the result.
def getAccessToken():
    url = "https://developer.api.autodesk.com/authentication/v1/authenticate"
    payload = 'client_id={client_id}&client_secret={client_secret}&grant_type=client_credentials&scope=code%3Aall%20data%3Awrite%20data%3Aread%20data%3Asearch%20bucket%3Acreate%20bucket%3Adelete%20bucket%3Aread%20account%3Aread'
    headers = {
        'Content-Type': 'application/x-www-form-urlencoded',
    response = requests.request("POST", url, headers=headers, data=payload)
    json_data = json.loads(response.text)
    return json_data["access_token"]
token = getAccessToken()
def getDrawingFiles(folderId):
    url = f"https://developer.api.autodesk.com/data/v1/projects/{project_id}/folders/{folderId}/search"
    payload = {}
    headers = {
        'Authorization': f'Bearer {token}',
        'x-user-id': userId,
        'x-ads-region':'emea'
    response = requests.request("GET", url, headers=headers, data=payload)
    print(json_data)
getDrawingFiles('urn:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx)
 Please can anyone offer some advice?
3 REPLIES 3
mikako_harada
I assume you are using BIM 360 Docs based BIM 360 (not BIM 360 Team which is A360 based).
If so, could you try removing the app in account admin >> custom integration tab, (click “Detail” >> remove app),
and go through the integration process again?
We had a case in the past where re-provisioning helped.  So could you give it a try?
Mikako Harada
Developer Technical Services
in reply to: mikako_harada
Thankyou for your response. I tried that but it still returns the same error message. It seems like the problem might be with the data:search included in the scope because the api works for all requests requiring data:read.
Please let me know if anything else comes to mind.
Kind regards,
Timothy
mikako_harada
Re-reading the documentation,
https://forge.autodesk.com/en/docs/data/v2/reference/http/projects-project_id-folders-folder_id-sear...
I noticed that it says:
"Authentication Context:  user context required"
"Authorization:  Must be Bearer <token>, where <token> is obtained via a three-legged OAuth flow."
It does not says, x-user-id as possible header parameter.  So looks like it only supports 3-legged authentication.
You will need to implement a logic to recursively look into each folder:
https://forge.autodesk.com/en/docs/data/v2/reference/http/projects-project_id-folders-folder_id-cont...
Mikako Harada
