AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Sweep_mesh tool demo released
Bruce.Lee.
Bruce.Lee.
The Sweep_mesh tool is finally released, and I made some demos of the tool.
Hope you like it!
Thank.
moiamy
Hi Bruce. Is there an issue with Maya 2023 ?
I tried both version and somtething wrong.
Bruce.Lee.
Are you on version 2.5? It requires version 2.5. Or you can go inside it and see which node is at fault.
moiamy
Yep I was on 2.4. Sorry for that
dajinya927
Community Visitor
Community Visitor
Hi Bruce,your lightning node can not produce  Level123 's material shader, can not edit their own material, only by a material, in Maya2023, Bifrost 2.5.
labs3d
Rotate and twist from the general section of sweep mesh 02 does not work in bifrost 2.12 in Maya 2024, could it be due to the version?
