i need the installer for a SPECIFIC version of Bifrost to match machines already setup... but the extensions section of the products and upgrades page only has a couple of versions available, neither of which are correct... is there a WORKING link for a repository page with ALL the previous releases?
i need 2.7.0.0...
a
Solved by yeungy. Go to Solution.
Hello!
There is a drop-down list on the right-hand side called 'Release Date'. Could I ask you to please try changing that to All and see if you can find what you need?
In other words, click on Product Updates on the left, then the Extensions tab, then change the Release Date drop-down to All.
Thanks!
