Setting color to instances
labbejason
labbejason
Hey all,
After passing through a mesh into `geo instance` then `set instance shape`, is it possible to change its point color so that each instance can be colored individually? I tried using a `set geo property` but this only takes effect if it's done pre-instance instead of post. Thanks!
Christoph_Schaedl
Does this thread help?
https://forums.autodesk.com/t5/bifrost-forum/driving-shader-properties-on-instances/td-p/9736348
https://linktr.ee/cg_oglu
labbejason
I did see that thread unfortunately all of the examples are showing grey for me. They have no errors on open so not too sure what to make of it.
jonah.friedman
Indeed, that example is how you set colors on instances for your Arnold renders. In the viewport I'm afraid it's not currently possible.
Jonah Friedman
Bifrost Product Manager
labbejason
Thanks for the clarification, but all scenes are rendering black for me too using Arnold.
Christoph_Schaedl
They scenes render fine here with Arnold MtoA 4.0.4.1
labbejason
They're probably fine then, my version must be too old to support it. Living in the past, ya know? 🙂
