Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
set instance geometry and bifrostgeotomaya
26 REPLIES 26
Message 1 of 27
4530 Views, 26 Replies
is there a way to connect a set instance geometry nodes output to a bifrostgeotomaya node? i wish to render particle instances in redshift
26 REPLIES 26
Message 21 of 27
martinmichl
hello,
I downloaded your "bifrost_to_nparticle.zip" and ran it in Maya2023.
the connection to the nParticels seems to be broken.
Any clue how to fix this?
Thank you so much
Message 22 of 27
Sorry in this moment my laptop is broken.
I let you know soon
Message 23 of 27
Hi, maybe you didn't install the arrayMapperCustom plugin.
This:
https://forums.autodesk.com/t5/bifrost-forum/set-instance-geometry-and-bifrostgeotomaya/m-p/10327745...
let me know
Andrea
Message 24 of 27
syracoj
you should be able to plug a baked_instanced_geometry node after the create_instances in your graph and then use the baked_instanced_geometry mesh output to connect to the bifrostGeoToMaya node but these will no longer be instances it will just be a mesh.
Message 25 of 27
I have tried to update the arrayMapper, but it is not very performing.
https://youtu.be/5yXg_5c2blc
Message 26 of 27
I tried to change method to transfer attributes from bifrost to Mash or instancer. I think mash is better for the cache.
https://youtu.be/h73jTnokoM8
Message 27 of 27
randy
in reply to: syracoj
THIS!! Totally the solution I needed.
Technology Administrators
