Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
scale a volume containing particles
adrian_wyer
Message 1 of 12
adrian_wyer
seems pretty straightforward, but once i started digging i got dirty 😉
i want to emit a set of particles (not moving) from within a mesh volume (a branch structure of the universe, the particles are galaxies)
i need to scale the branch (actually push deform along it's normals, easy enough) but as the branch swells, i need the galaxies to keep their relative position in the volume, so they slowly scale AWAY from each other (while remaining the same individual scale) showing how galaxies are drifting apart as the universe scales.....
would love to hear anyone's idea on how to achieve this!
thanks
a
Replies (11)
Message 2 of 12
adrian_wyer
in the end i used a selection of curves as emitters and gave the galaxies random spread direction and speed.... seems to work... now if only i could instance the galaxy geo to random particles whilst preserving the redshift shader setups..... 😞
Message 3 of 12
sepu6
Message 4 of 12
adrian_wyer
holy hell that's amazing... thanks!
a
Message 5 of 12
adrian_wyer
no .mll/compounds on the github page, as mentioned in the documentation... does this mean you have to compile yourself?
Message 6 of 12
sepu6
Not need to compile if you use 2024 - for earlier versions you have to.
Message 7 of 12
adrian_wyer
i'm using 2023 😞
is there some documentation explaining why it would need compiling for earlier versions?
does maya 2024 have a built in compiler?
or is there a new format for plugins?
not finding anything on this...
can't really upgrade either as rest of the company is mid project...
Message 8 of 12
morten.bojsen-hansen
@adrian_wyer Because the download comes with the plug-in already compiled for 2024.
Message 9 of 12
adrian_wyer
found it, was downloading the wrong thing on github... PEBKAC...
thanks
Message 10 of 12
Message 11 of 12
adrian_wyer
yeah got there eventually, not used to github.... low key end user hat on 🙂
a
Message 12 of 12
adrian_wyer
ok, got it all installed and working, particles from bifrost.. however... seeing as the farm/redshift versions are frozen for now at an older version that doesn't support maya 2024, i wanted to cache the particles and open the cache in 2023... but can't  write an ncache for the particles... and alembic doesn't seem to work either
don't suppose anyone has compiled the plugin against 2023?
