Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Random range of particle sizes and colors
4 REPLIES 4
takaharu_tobe
341 Views, 4 Replies
When I want to give random values ​​to the size and color of Bifrost particles, I only know how to use a noise field.
For example, how can I create randomness between a minimum and maximum value?
Best regards,
4 REPLIES 4
sepu6
in reply to: takaharu_tobe
Use the vary source property node and change the size of the pts, you can randomize many attributes with this one before your simulations, check the info tab.
Thank you!
I was able to specify a random range for size and color with vary_source.
I connected it using the Bifrost Browser sample as reference, but does color and source_color_property both seem to be necessary?
sepu6
Yes, you need it there so the particle solver knows about that property and you can randomize it.
@sepu6
Thank you very much.
