When I want to give random values to the size and color of Bifrost particles, I only know how to use a noise field.
For example, how can I create randomness between a minimum and maximum value?
Best regards,
Solved by sepu6. Go to Solution.
Use the vary source property node and change the size of the pts, you can randomize many attributes with this one before your simulations, check the info tab.
Thank you!
I was able to specify a random range for size and color with vary_source.
I connected it using the Bifrost Browser sample as reference, but does color and source_color_property both seem to be necessary?
Yes, you need it there so the particle solver knows about that property and you can randomize it.
