PRINT_PACK Version 2.7 - Printing in Bifrost just got easier
Roland.Reyer
Alumni Alumni
Roland.Reyer
*** UPDATE *** Version 2.9 is available here:
https://forums.autodesk.com/t5/bifrost-forum/print-pack-version-2-9/m-p/12368334?search-action-id=84...
This is version 2.7 of my PRINT_PACK.
The goal of this version is to make printing in Bifrost much easier.
Instead of different print node for various task (which are still there) it offers you a simplified "print" node for scalar values and for arrays.
Here'a a tutorial video:
https://youtu.be/gdop9N9SFs8
New features:
print
A new node with simplified settings for scalar values and arrays
print_to_string
For use within loops.
Print up to 16 description-value pairs to a sting.
print
print_static
print_scrolling
The value inputs can now be scalar, strings and arrays.
Arrays will be printed in a single line, which helps display small arrays together with scalars.
WORD WRAP for longer texts works in Rich Text as well as in Fast Text
Fixed:
Special characters will now be ignored
Min/max sizes for string in print_array
Print_object_properties now also displays properties that have "indices" instead of "data"
A single character was not printed with rich text
any_array_to_string: Corrected min/max info, now from the whole array
thomaslisle1309
Looks super helpful many thanks
DavidHenion
How to install?
Christoph_Schaedl
Just drop it into this folder. C:\Users\UserName\Autodesk\Bifrost\Compounds
If the folder does not exist create it.
Or the more elegant solution create your own folder and add an environment variable like this.
BIFROST_LIB_CONFIG_FILES=C:\....\print_pack\bifrost_lib_config.json
https://linktr.ee/cg_oglu
DavidHenion
Ok, thank you - I was trying to put it in the C:\Program Files\Autodesk\Bifrost\Maya2023\2.7.1.0\bifrost\Compounds folder, not under users.
mcw0
So just place the "print_pack_V2.7" folder in C:\Users\UserName\Autodesk\Bifrost\Compounds?
Christoph_Schaedl
Yes or set an "environment variable" like i did here for BulletFrost.
This way you can better manage your compounds if you need different version or use different Maya versions.
https://youtu.be/HAHfqk7Z7u0?si=WAUHebaRoazP2q-n
