Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Create a texture in Bifrost
8 REPLIES 8
Message 1 of 9
mitch.s
376 Views, 8 Replies
Is it possible to create a texture from bifrost.
To illustrate this (not the actual application) I have a simple proximity map on a torus that I'd like to 'bake' / 'create' a texture from.
Ideally on locations per pixel on a uv.
Is there a way?
8 REPLIES 8
Message 2 of 9
Christoph_Schaedl
in reply to: mitch.s
Use the paint vertexcolor tool in maya.
https://help.autodesk.com/view/MAYAUL/2022/ENU/?guid=GUID-18457833-2003-41E2-A174-BCF0B18957A5#GUID-...
https://linktr.ee/cg_oglu
Message 3 of 9
mitch.s
in reply to: Christoph_Schaedl
Thanks @Christoph_Schaedl
But how do I get the vertexmaps created in bifrost inside artisan?
Message 4 of 9
Christoph_Schaedl
Convert the bifrost mesh to a maya mesh. Right click onto the output node. There is the convert option. You need the latest Bifrost version for this feature.
Message 5 of 9
mitch.s
Thanks again for the quick response.
I'm working in Maya 2023 with bifrost 2.5
I used a bifgeo_to_maya node to get a maya mesh. But I can't find any colorsets to export...
Message 6 of 9
Christoph_Schaedl
Fastest way would be to install Bf 2.7
Message 7 of 9
sepu6
Check this, even though is 2.6 you do the same for 2.5
https://youtu.be/dbZycDK17Uw?t=280
Message 8 of 9
mitch.s
Same thing in Bifrost 2.7.
Probably there somewhere. But I just don't know where to look for the colorsets (except from the colorset window)
Message 9 of 9
mitch.s
Ok, it works in Bifrost 2.7.
I had a viewport update issue
