i use infection simulation for growth but got error when the tree is spawned, they blink continuously to a point complete, what do i need to do to fix that please help and thanks
Solved by sepu6. Go to Solution.
is because your point cloud is changing over time and that will make jump the instances. Instead of using the "infected points" use the "all point" ports and use the "emit" property on the mask weights of the instances.
I'm stuck at this part, it seems that mask weight can't get property 'emit' from infection
Check your data, press W between the wires, the emit property is a float, not a vector. Also, you can use a string to call the attribute on the mask weight, since is an auto port.
