Manipulator Field Version 2 (**UPDATE** 2.01)
Roland.Reyer
Alumni Alumni
Message 1 of 11
Roland.Reyer
Finally version 2 of the Manipulator Field is ready.
In version 2 the Manipulator Field brings some technical improvements.
  • the performance was improved
  • the direction of the "Around Axis" in the cube shape has been corrected
  • the effect of "Erode ID" has been significantly improved
In addition to the Manipulator Field, the Shelf now contains additional tools.
  • a "Sphere Field", a simple sphere manipulator with a scalar field
  • a "Box Field", also a whole simple scalar version of the field
  • a "Position Manipulator", creates a locator and connects the matrix to the bifrost graph - for convenience
  • a "Direction Manipulator", makes an arrow manipulator and connects the matrix to the bifrost graph - for convenience
IMPORTANT 1: the scripts for these functions can be found in a new MEL file.
IMPORTANT 2: if something seems not to work, or if you have trouble installing it - please let me know.
For the functions of the Manipulator Field I refer here to videos for version 1.
Replies (10)
Message 2 of 11
Christoph_Schaedl
Thanks Roland those Manipulators are really handy.
https://linktr.ee/cg_oglu
Message 3 of 11
moiamy
Hello @Roland.Reyer
With V2.1 version when I want to add a second manipulator :
source addManipulatorField_2.mel;
addFieldManipulator_2( "", -1, 2);
// Warning: file: C:/Users/B/Documents/maya/2022/scripts/addManipulatorField_2.mel line 118: Unclear selection! Please select a Bifrost Board or one of its manipulators. //
// Warning: file: C:/Users/B/Documents/maya/2022/scripts/addManipulatorField_2.mel line 471: BifrostBoard doesn`t exist or has no Manipulator Field with that number //
I have selected in BG my Manipulator_Field compound before pressing the shelf button
Here is my shelf arrangement :
Does it speak to you ?
Message 4 of 11
sepu6
Select the manipulator first then click on the button, so for example if you have `mf_0_volume` click on that first then the shelf tool with the green icon, and that will add another manipulator to be use with the same settings if you need a completely new one so they do not share the same setting then just click v2 button or simple ones.
Message 5 of 11
darioOrtisi
I get this error
addManipulatorField_2( "");
// Warning: file: C:/Users/xxxx/Documents/maya/scripts/addManipulatorField_2.mel line 150: Please select ONE Bifrost Board, Bifrost Shape, or a connected object to create a Manipulator Field for //
// Warning: file: C:/Users/xxxx/Documents/maya/scripts/addManipulatorField_2.mel line 660: No such bifrostBoard exists >< //
Message 6 of 11
sepu6
Literally, I responded to the same question that you are asking. Read my response.
Message 7 of 11
darioOrtisi
Yes i did it. There was something wrong in the scripts. I restart Maya, not work. I reinstall the plugins now is working.
Message 8 of 11
Roland.Reyer
There is a little glitch in the Shelf of Manipulator Field V2.0 (at least in my Shelf):
The "Cleanup button isn't working because it calls the wrong function.
Instead of addFieldManipulator it should call mf_cleanup("");
You can change this yourself or load the new package from here.
I apologize for the inconvenience.
Message 9 of 11
Christoph_Schaedl
Thanks for the update Roland!
Message 10 of 11
darioOrtisi
Thanks @Roland.Reyer  it was that.
Message 11 of 11
darioOrtisi
@Roland.Reyer Iv'e ispected my scene, before cleanup by hand. I've noticed that the error i get, was when the graph has some non utilized nodes. I usually try multiple variant of connection, non erroring node. When i canceled this node, the addFieldManipulator add the manipulator correctly.
