Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Geo_Modifier
Geo_Modifier
Aslan.Jafari
Autodesk Autodesk
Geo_Modifier
Aslan.Jafari
Geo_Modifier
This compound will analyze and break down a geometry into individual faces with enough information to reconstruct the geometry.
User can build their own FX with the available data extracted from the geometry inside "per_face_data_manipulation" compound.
Geo_Modifier > per_face_data_manipulation >
Input and output of per_face_data_manipulation compound is: array<array<Math::float3>>
Indices of arrays within the array<array<Math::float3>> correlates  with the face indices of the geometry.
A simplified way of thinking of this is: Array[0]= Face[0]
Attached video demonstrates a simple use case for Geo_Modifier compound.
Aslan Jafari
Sr QA Analyst
concatenaN6AA3
Thanks! What about UVs ?
sepu6
You can get the UVs and then set them after the operation.  You could also try to transfer them with `transfer_properties_by_indices`
concatenaN6AA3
Aja! I didn't know this nodes. I will Try it. Thank you very much.
