Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Export geo property to color set
3 REPLIES 3
overalgu
424 Views, 3 Replies
I have a compound which calculates the highest and lowest point of a given mesh and then it writes it as a property from 1 to 0 into the geometry (screencap bellow).
I want to use this generated property as a mask for a mix shader, so i can use different materials based on height, i tried using the aiUserDataFloat, but it doesn't work as a mask.
Is there anyway to export this data as a color set? Or any other way to use this information to make my mask?
Labels (3)
3 REPLIES 3
overalgu
in reply to: overalgu
The generated point property and the graph
EddyMagic
Hello Overalgu,
did you find a solution ?
I have the same need.
Edgard
Have you seen my workflow here.
https://youtu.be/0elj1q6k5L0?si=uF1xoWXE2GpWTUSS
https://linktr.ee/cg_oglu
Just playing with the new Scatter nodes in Bifrost. If you updated to Arnold MtoA 4.2 make sure you are using Bifrost 2.2.0.2 Assets used in this video are from Quixel. Social: https://www.artstation.com/oglu https://twitter.com/ChristophSchadl
Technology Administrators
