Hello my friends!
Could you help me for:
1) Convert the result of the Absolute Value node to volume
2) After #1 create a vector that's going to point towards the direction where the greatest change is happening and that is going to help us to create a force that we can use to displace particles
3) Create a velocity Control to Push the particles from the high-frequency oscillations areas to areas with low oscillation
Thank you 🙂
Solved by sepu6. Go to Solution.
I just responded to you on the discord but for whoever is not there, you need to grab the result of the absolute node and put it into a property/attribute and then convert it into a volume SDF and convert that property into a field so you can grab the gradient and create the field that you need. Then you can use it in your sim.
