Hi all,
I'm looking to freeze a bifrost basic particle emitter so I can get the 'bullet time' effect by swinging a camera on a motion path around the sim, while it's frozen, and then continuing the animation. I've tried disconnecting the time node from the bifrost emitter which works but my surface, a sphere on a motion path, continues to move. I've resolved that bu moving the motion path endpoint and adjusting the frame number to stop the sphere at a specified point on the motion path however the particle emitter keeps, well emitting. Any help would be appreciated. Thanks.
Maya 2020.4 | OS 10.14.6
2013 Mac Pro 12 core 64gb
there is a simulation speed setting in the solver node, i think.
you could try to hook it up to an input node and keyframe it in the bifrost shape.
edit: you can start and stop the simulation like this. it fades in and out, according to you animation curve. take a look at the screenshot.
