Hello!
I have a read_bifrost object node issue. I am using the time node, as I previously have. "to_long" as well. The output only detects particles (for sim) when I select a frame, but when using #### I am unable to read sequence. The output detects No (0) objects. When using a particular frame, the sequence also does not read. Time - To long - To .bob
Any issues here? I tried creating a new bifrost graph, but same issue. The only thing I haven't done is reset preferences. Scene is 84mb.
Actually… not resolved. Any help would be appreciated. I use time node and if conditions successfully with alembics, but .Bob sequence giving me issues. Need the sequence start frame to begin at different time.
They work fine for me dude. How are you hooking it up. Can you show a screen shot? And what is the if condition for?
The hashes are replaced with the incoming frame input. I have the filename in a value node just so I can plug it into the two nodes for ease of use.
