Bifrost Programming Question
anthony6UVHQ
anthony6UVHQ
Does the Bifrost program permit two "point_scope" nodes. each with its own separate input and output, to be used in the same bifrost graph selecting parameters to show two different colors when run simultaneously?
morten.bojsen-hansen
Yes, see here:
anthony6UVHQ
Thanks Morten.Works fine.
T
Still stuck with Marcus issue.
anthony6UVHQ
Aside from cacheing a .bob file, what mesh formats can be entered directly, without cacheing, as direct input to a Bifrost graph. I have used wavefront obj format successfully but what others can be used and particularly for rigged and animated applications.
