Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Bifrost Programming Question
3 REPLIES 3
anthony6UVHQ
385 Views, 3 Replies
Does the Bifrost program permit two "point_scope" nodes. each with its own separate input and output, to be used in the same bifrost graph selecting parameters to show two different colors when run simultaneously?
3 REPLIES 3
Yes, see here:
Thanks Morten.Works fine.
T
Still stuck with Marcus issue.
anthony6UVHQ
in reply to: anthony6UVHQ
Aside from cacheing a .bob file, what mesh formats can be entered directly, without cacheing, as direct input to a Bifrost graph. I have used wavefront obj format successfully but what others can be used and particularly for rigged and animated applications.
