Bifrost MPM fluid for making mud
Bruce.Lee.
Message 1 of 20
Bruce.Lee.
Bifrost MPM fluid. MPM fluid has more advantages in physical properties than FLIP fluid. MPM fluid can be viscous and elastic, while FLIP fluid cannot possess elastic characteristics.
Replies (19)
Message 2 of 20
Christoph_Schaedl
Bruce could you share the graph?
This is to cool to be lost.
https://linktr.ee/cg_oglu
Message 3 of 20
Bruce.Lee.
I have uploaded my scene file to the sharing community and should be able to download it after passing the review
Message 4 of 20
Christoph_Schaedl
Thats great Bruce.
Let the Bifrost community grow!
Message 5 of 20
morten.bojsen-hansen
https://area.autodesk.com/downloads/mpm-fluid-mud/
Here's a link for future reference. Amazing work as usual Bruce Lee!
Message 6 of 20
Christoph_Schaedl
Bruce somehow i cant get it working.
There are some .alembic files missing and nodes are disconnected.
If i hit play nothing happens.
Message 7 of 20
Bruce.Lee.
You need to install the "point_color" node, which can be downloaded in the sharing community.
I have cancelled all the abc files and it should have no effect on the results.
thanks.
Message 8 of 20
Christoph_Schaedl
Thanks downloading now.
Message 9 of 20
Hi @Bruce.Lee. this graph looks so cool. Would it be possible to reupload the graph? I cant find it inside the Area anymore. Thank you anyway for your work! 🙂
Message 10 of 20
Bruce.Lee.
Don't worry, it's here 🙂
Message 11 of 20
woah thank you so much! 😊
Message 12 of 20
psyteck
Did you got the mud working?
I also did download the color_point node.  But I can not reconnect the node.
How did you it, if yours is working.
Message 13 of 20
mihirsbcc
Greetings Bruce, your works are amazing. I have been learning a lot from your examples. I am an instructor and exploring you all materials in the forum to share with my students. Thanks for doing that.
Message 14 of 20
mihirsbcc
Hi There, did you mange to connect the point_color node for mu example? If yes will you please share how you did it?
Message 15 of 20
Bruce.Lee.
Have you tried the point_scope node? This is a tool for debugging point attributes, I hope it will help you.
Message 16 of 20
mihirsbcc
Thanks Bruce, I opened your scene and found point_color is already
connected, but convert to volume is giving me error. The point_color is
fine. I know it is looking for some input.
Message 17 of 20
mihirsbcc
hi there,
I hope you managed to connect the point_color to convert_to_volume to complete the graph
Do you think you can tell me which port of convert_to_volume i should connect from point_color?
Thanks.
Message 18 of 20
Bruce.Lee.
I don't think the point_color node is needed, so I can skip it. You can use points_to_volume and volume_to_mesh nodes to generate meshes for rendering.
Message 19 of 20
mihirsbcc
Thanks Bruce.
Message 20 of 20
mihirsbcc
It worked, wrangled a little bit with nodes and now sim works. It takes some time. I will complete the sim later.
