Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Bifrost Graph mpm particle count display?
5 REPLIES 5
PhilRadford
740 Views, 5 Replies
quick one. Is there a way to show mpm particle counts as numbers?
Thanks in advance
Phil
5 REPLIES 5
Doesnt the Watchpoint give you the data?
https://linktr.ee/cg_oglu
oh yeah...lol..hahahha thanks
If you look closely, you'll notice that put your watchpoints on aray in/outputs (as evident by the little hats on the ports(. Currently, watchpoints are limited to showing the size of arrays. If you want to see what's in a specific object, you need to use first_in_array or get_from_array on the granular_particles output first, then you should be able to see particle properties.
Perfect, makes sense. Thanks Morten.
