Bifrost develops lightning tool demo 1
Bruce.Lee.
Message 1 of 143
Bruce.Lee.
HI,
Lightning tool developed using Bifrost 2.1 version point cloud. And, I used this tool to make the first demo. You need Bifrost 2.1 version and Rebel Pack 0.3.0 to run this tool.
This is only the first version, and I hope to update it in the future. My goal is to make it easy for everyone to create any type of lightning effect.
Of course, I also hope that the official BIfrost team can release better lightning tools in the future.
I upload the file here. And, I will upload it in the compound sharing area.
Please enjoy!
Thanks!
Demo:
Tutorial:
Replies (142)
Message 2 of 143
mjcg91
Great work Bruce.
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
Message 3 of 143
Christoph_Schaedl
Thanks thats great!
https://linktr.ee/cg_oglu
Message 4 of 143
doppelgaenger_digital
Amazing! Great work and thank you!
Message 5 of 143
PhilRadford
Amazing Bruce ! Thanks for showing us your workflow. That's quite a graph !!
Message 6 of 143
takashima.
Great work! Thank you for sharing 🙂
Message 7 of 143
Bruce.Lee.
thank you all! I have a plan, hoping to make this tool more flexible. I will continue to do it. I also hope that more people can participate in the tool production process. Everything is developing in a better direction 🙂
Message 8 of 143
PhilRadford
This is what will make Bifrost great. Lot's of people creating compounds so that when you want to make something cool you wont always have to go deep . The artist will have loads of compounds as a starting point . Iv'e started to create a whole library of artist friendly compounds for myself, made from different elements from different compounds and other peoples scenes . Even something simple like creating an mpm sand set up I have turned into a single compound and published it so that I don't have to create a simulate mpm node and a mpm solver node every time I want to use mpm . So much like houdini we will have a whole bunch of compounds ready to go . What I am enjoying is going deep into other artists graphs and some of my own and grabbing certain groups of nodes that do certain things and publishing compounds and then mixing these with other compounds, it's great ! great work dude !
Message 9 of 143
Qu!ck
Hi. Great tool. Is it possible to convert lighting to mesh or curves?
Message 10 of 143
a_baranov
Hi, thanks for the great compoud. But is there a way to render it not with arnold but redshift? Can I convert lightning to mesh or something, that other renderer can see?
Thank you!
Message 11 of 143
Bruce.Lee.
You can use the "write_Alembic" node. Export the strands into a single abc file. (Be sure to check the "write_single_file" option.)
Then in the top menu of Maya: Cache> Alembic Cache> Import Alembic. The strands will be imported into Maya as curves. Finally, render with any renderer.
Message 12 of 143
Bruce.Lee.
As mentioned above.
Message 13 of 143
Qu!ck
I'd tried this. Write_Alembik node have strange behavior. It write equal to or less  number curves then was in the first frame. Same for particles too
Message 14 of 143
Bruce.Lee.
This is a sample file. It works normally.
Message 15 of 143
Bruce.Lee.
Bifrost can export particles as abc files. However, Maya cannot read particle files in abc format due to its own limitations.
Message 16 of 143
a_baranov
Thank you for this workaround! Will try to use it. 😉
Message 17 of 143
Qu!ck
Yes. But try this :
Message 18 of 143
a_baranov
Thank you!
PS. Too bad that in current version of BGraph we have no ability to connect strands dirrectly to maya curves or at least to hair system. It could save a lot of time. 😞
Message 19 of 143
286380064
 use "extrude strands"(MJCG compounds's node)  export  mesh  ,
the "levle1" channel can't render in arnold .
the "body" channel can render in arnold .
Message 20 of 143
a_baranov
Thank you so much again and again.
Looks like this tecnique works completely as I wanted in redshift. Even UVs are there. I've managed to work level1,2,3 and body. Something is strange when you try to playback when every extruded tube is visible, but once you render frame by frame everything is good.
