woudn't it be cool to know how different processors perform with bifrost?!
it can help us build better pc and workstations for bifrost simulations.
I have never created a benchmark before so it may not be that good but i hope that even in it's current state it come in handy.
currently it's only for Aero, let's check it and if it was working as expected i will add mpm and instancing as well.
when you open the scene file you will see this window.
when you run any of the aero sims it will write a text file for you with your spec and simulation time
after that we have 3 button each one will run a simulation.
after you run each simulation it will show the simulation time in the fields on the right.
Moderator's note: Removed the scene due to it containing the scriptJob described here. Please use the security tools for Maya. An updated version has been posted in the thread below.
Solved by morteza.cg. Go to Solution.
Solved by cescocm. Go to Solution.
i only have some low end cpu around to test this with. i really like to know how long it takes for more power processors to simulate these.
This is awesome, thanks for making something like this. Everyone loves benchmarking simulation. I've shared your post on the Bifrost Addicts Slack channel. If you'd like to join, I believe people will share their benchmark results: https://join.slack.com/t/bifrostaddicts/shared_invite/zt-jq7gwf53-AtAgPGWF_NPan_Tu7cfJTw
In the meantime, here are my results:
This is a really nice benchmark tool Morteza! My personal PC config is pretty similar to yours so I guess my test results should be close to yours. Thanks for sharing this!
Thanks, I'm glad you guys liked it.
I didn't know about the Bifrost slack channel, I will join now.
Hello, here my results:
Also, keep in mind that the scene has this this scriptJob.
I cleaned it from the .ma before opening the scene because last week we had the same issue in my workplace. I'm also attaching the cleaned .ma just in case.
Cheers!
Thank you for the fix!
I can't seem to edit my post, I've notified the moderator hopefully they will change my attached scene with yours.
Very cool tool (and it's very interesting to see the results too!)
I have removed the attached scene that contains the bad scriptJob though - I didn't post the updated one though as that might be taken as a verification that it's clean, which we haven't done. Feel free to accept @cescocm's post as a solution though to draw more attention to that post. Thanks!
I tried your scene. When I opened the scene, it gave me the famous Maya's error........ An error occurred while reading file. There will be data lost..... I ignored it. selected the Explosion tab and play the time line of 200 frames. It crashed after completing 1oo frames. I will try it again and keep an eye on it.
Interesting.. after running Yuri's (@1usmus) CTR diognostic, I got stable figures for an undervolt/overclock and created a test profile in ryzen master. Looks like it lowered my cpu temps while shaving a few seconds off this test. Still no threadripper lol but cool if it remains stable with day long renders.
Great initiative.
Here are the results for two other machine configurations:
I also just want to point out that there are a few ways to speed up the benchmarks and simulations in general as shown in this image:
Thank you for the tips Michael specially the Viewport bypass processing.
Thank you for this, I'm gonna try running this on my 3990X. I do have a question though, when I open the file, the benchmark window doesn't pop up, how can I get it to open?
I have a 3990X and ran the sims, the times are above. Is there any way to script this? I'd like to run it on some other machines.
Hi @michael_nielsen when I try connecting that has_property node like you show, I get an error. I think it's because the updated scene doesn't have the "found" property on the output node, but I'm probably missing something here.
