Hi everyone!
is there a way to convert *bif to nparticle? like openVDB has node bifrost to Array output out_position that connects destination of node nparticle position input and has additional dynamic array concatenated to cache array data nParticle.
similar to this clip:
Solved by sepu6. Go to Solution.
Try this.
https://forums.autodesk.com/t5/bifrost-forum/set-instance-geometry-and-bifrostgeotomaya/m-p/9086294
I have not tested it personally but it could work.
Out of curiosity why do you want to pass particles to N system?
Thanks! sepu6, i want to render to particle with redshift because it's much faster when baking to geometry
