Align locators with points normals from a surface
moiamy
moiamy
Hello
1. I have a Locator following a curve (coming from an edge  surface)
2. I would like to align the Y axis locator with the closest points normals from this surface
3. As it seems we can't import locators inside BG, I tried to align a cube first, with a sphere taking informations about closest point on surface.
But I guess I am doing something wrong about the part when I want to copy the orientation
moiamy
update : I finally use sample property to get the position and the normal.
Now I try to figure how to use these infirmations to constraint an object orientation in BG
dg3duy
@moiamy I am researching the same as you, how did your research go in the end?
