Installing Trueview 2018 in Windows 10 32bit
Message 1 of 16
When I try to install last version of trueview 2018 in a Windows 10 32bits using the the standard 32bits installation in
https://www.autodesk.com/products/dwg/viewers
the installer refuses to install because the operating system is not supported.
The System Requirements link is on window is :
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/System...
But the product is Trueview , not Autocad.
Also the existing link for System Requirements in
is Trueview 2017
 https://damassets.autodesk.net/content/dam/autodesk/www/products/DWG%20Viewer/docs/pdf/DWG_TrueView_...
but finally in this document I cannot see any problems with 32bits.
Any help will be appreciated.
Replies (15)
Message 2 of 16
pendean
Community Legend
Community Legend
is your Windows version 32bit?
What is your Windows version?
Message 3 of 16
 As I have described, Windows 10 pro 32 bits.
But the processor is x64.
Message 4 of 16
pendean
Community Legend
Community Legend
Is the file you are downloading called
DWGTrueView_2018_ENU_32bit.sfx.exe
Or something else?
Sadly it's no longer 1999 and we don't have 32bit PCs with Windows 32bit in the office to test it for you.
Message 5 of 16
Exactly like that.
Message 6 of 16
Is there any log to show me what's happening?.. Maybe it's a detection fault. I didn't find it.
Message 7 of 16
Ok I found it.
In file sysreq.chm in en-us/Docs subdir "Note DWG Trueview 2018 is not supported on the 32-bit versión of Windows 10". Incredible. As Autocad 2018.
But they eliminate the possibility to download previous versions. Then you need to Google 2017 version if you want to download it.
Well, I will try it or I will change the Windows version to x64 or something more creative...
Message 8 of 16
m_latz
Here can you download previous version:
Previous TrueView version ...
regards
Markus
Message 9 of 16
I also have the same trouble and have been well resolved, thank you very much.
Message 10 of 16
It could be done touching the installation files and removing the limitation. It works.
Message 11 of 16
I have solved the problem according to your method and again thank you very much. And I got some reference from the following article.
Message 12 of 16
Can you please explain how "touching the installation files"? So you got it to install on a Win 10 32-bit machine?
Message 13 of 16
m_latz
Generally if Autodesk disables the Windows 10 32-Bit support, there is a reason why, so in a productive environment, you should not do this !
But for other reasons you can just remove the "system requirement check" from the setup.ini file, then you can install Autodesk Trueview 2018/2019 also on Windows 10 32-Bit.
Comment out the following lines in the setup.ini file:
regards
Markus
Message 14 of 16
Thanks, I actually figured out how to do that, and it worked.
Message 15 of 16
   That's a typical comment from Eggheads who only do what Microsoft tell him to do.   Grownups in this field know that people have legacy systems they are supporting. You probably weren't even born in 1999.
  Comments like this from people like this have ruined the professionalism in the industry.  If you were as smart as you think you are you'd be using Linux anyway ....
Message 16 of 16
Nice solution but why does Autodesk not include the corrected version of "setup.ini" for installing TruView on a 32 bit system within the file "DWGTrueView_2019_Enu_32bit.sfx.exe" which was especially prepared for this installation on a 32 bit system?
best regards
Richard
regards
Markus
