Differences between Insight 360 and Green Building Studio.
carol_poon
Autodesk Autodesk
carol_poon
Is Insight 360 going to replace Green Building Studio? Currently, I see both software are available in Autodesk website for trial.
Mohammad_Asl
Green Building Studio is the back end engine for Insight360. Insight360 provides a sensitivity analysis and combined factors for high performance building design. You can use insight360 to have real tim einteraction with the design parametrs and compare the perforamnce with benchmarks.
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
Mohammad Asl
High Performance Building Design Researcher
Autodesk, Inc.
Insight360.support@autodesk.com
hq.cheng
Can you go into details about the relationship between GBS & INSIGHT? E.g. are the data used by Insight the same as the ones used by GBS, and can you show some supporting documents. Thx in advance!
