I am unable to access my Autodesk build subscription through the Autodesk Desktop app.
When I sign in, it says "You do no appear to have an Autodesk subscription or the product you are trying to install isn't available through the Autodesk desktop app".
Can Build not be used through the Desktop app? Or is there just an error in my install?
Solved by pendean. Go to Solution.
do you see it here?
since its a cloud service it may not even use the desktop app for anything
what did you install?
DarrenP
