Revit Structural Connections not uploading
I cannot seem to upload Structural connections into my Revit software. I downloaded the update but when I close Revit and re-open its blank.
Could anyone help me please?  btw I have the student version, would that make a difference? thanks
Accepted solutions (3)
natasha.l
Hello @Anonymous,
Please take a look at: Load a Structural Connection
"Unless structural connection add-ins are installed in your version of Revit, no connections will be visible to load. In these instances, use the generic connection to detail your model."
Maybe @Viveka_CD can provide more information regarding these connection settings on your version of Revit.
@nick.dit can you please confirm what version you are running?
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
Viveka_CD
Hi @natasha.l
Looks like the add-in works only on Revit 2017.
Hi @Anonymous
You have to check his system requirements.See HERE for more information.
The Autodesk Steel Connections for Revit add-on is only compliant with Autodesk Revit 2017
Also, see this article HERE for a solution to why Autodesk Revit Steel Connections 2017 does not work
natasha.l
Hello @Anonymous,
I wanted to check-in with you, I hope you were able to resolve the issue. Was the issue due to different versions?
If it was & you have access to the Revit 2017 version you can download & install it. Let us know if you have any more questions.
