I opened the desktop app to check for any hotfixes or updates for my Revit 2022 installation and noticed it's not listed like my other Autodesk products are. My version of Revit 2022 was installed using the new deployment method. Not sure if that has anything to do with it. Has anyone run into this? Is there a fix I can try so the desktop app sees 2022 as installed on my machine? The desktop app version is 7.0.21.17, which I'm pretty sure is the most up to date version.
PS
I'm logged into an Autodesk account with permissions to download and install the entire AEC collection.
Also while typing this out I noticed that the app keeps closing on it's own. I tried reinstalling it and I'm still having issues.
Solved by pendean. Go to Solution.
I figured that might be the case. I was hoping it might be a registry issue or a missing support file somewhere. I can get the updates from the account page, I just like the convenience of the Desktop App, plus this is the first time I've ever noticed a product missing from there.
Thanks.
Happens the same to me, with both Revit LT and Autocad LT. I have automatic Update and have downloaded and installed version 2022 of both, but Desktop App manages and updates only 2021 versions...
