So I am a student, and I have signed up for multiple different free versions of Autodesk. I have Autodesk Inventor Professional 2017, and I have been able to use it smoothly for almost a year and 1/2 now. Later this year, when I downloaded Fusion 360, it kept saying that I didn't accept the terms and conditions, or other various errors. After trying to go back and fix all of these errors, nothing changed, so I uninstalled and reinstalled Fusion 360. Now, every time I load it up it says "There was an error when logging into Fusion 360." After seeing this, I went to the support page:
After following through and searching everything, I couldn't find any of the errors that were listed, but I did find something else. When I was searching through the log, I found other errors like:
2017-09-09T04:55:17.785Z [AutodeskDesktopApp:864, 15988] [AdWebServicesUI ERROR] Webkit dialog: Request failed. Http error: 403 Forbidden. Network error: 202 Error downloading https://cdn.web-platform.io/artifakt/release/v1.2.0/Artifakt%20Element%20Regular.svg - server replied: Forbidden
Then it says:
Response:
403 Forbidden
HttpStatusCode: 403
HttpReasonPhrase: Forbidden
ConnectionEncrypted: true
HttpPipeliningWasUsed: false
ContentType: application/xml
Content-Type: application/xml
Transfer-Encoding: chunked
Connection: keep-alive
Date: Sat, 09 Sep 2017 04:53:57 GMT
Server: AmazonS3
X-Cache: Error from cloudfront
Via: 1.1 f456a26d3c39946d9572c71344a45264.cloudfront.net (CloudFront)
X-Amz-Cf-Id: uMBNecP7OujcjbbHhWNxcHTLiC4ZGWMQLNHpGon1XsBdo-VXu2zNow==
There were also some others, but all of them were mostly about how I was forbidden from accessing Fusion 360.
After some closer looking, I found that the log said that Fusion 360 was (I think) missing some file(s):
Request:
GET https://cdn.web-platform.io/artifakt/release/v1.2.0/Artifakt Element Regular.svg
User-Agent: AutodeskDesktopApp/7.0.6.378 AutodeskWebServicesClient/7.3.10.1801 Windows/10.296
Referer: https://accounts.autodesk.com/authenticate/otp/7d69d65e-77aa-4050-a202-d9d746fcd4b1?viewmode=desktop...
Accept: */*
Accept-Language: en-US,en-US;q=0.5
Does this mean I should download this .svg file? If so I do not know the process. When I searched this .svg file, it showed me the document tree, and it was full of errors.
Ps. Am I forbidden because it still thinks I didn't accept the terms and conditions? I don't think this is the case because of the missing file(s), but I have no knowledge of advanced autodesk troubleshooting.
Please send help!
