So I am a student, and I have signed up for multiple different free versions of Autodesk. I have Autodesk Inventor Professional 2017, and I have been able to use it smoothly for almost a year and 1/2 now. Later this year, when I downloaded Fusion 360, it kept saying that I didn't accept the terms and conditions, or other various errors. After trying to go back and fix all of these errors, nothing changed, so I uninstalled and reinstalled Fusion 360. Now, every time I load it up it says "There was an error when logging into Fusion 360." After seeing this, I went to the support page:
After following through and searching everything, I couldn't find any of the errors that were listed, but I did find something else. When I was searching through the log, I found other errors like:
2017-09-09T04:55:17.785Z [AutodeskDesktopApp:864, 15988] [AdWebServicesUI ERROR] Webkit dialog: Request failed. Http error: 403 Forbidden. Network error: 202 Error downloading https://cdn.web-platform.io/artifakt/release/v1.2.0/Artifakt%20Element%20Regular.svg - server replied: Forbidden
Then it says:
Response:
403 Forbidden
HttpStatusCode: 403
HttpReasonPhrase: Forbidden
ConnectionEncrypted: true
HttpPipeliningWasUsed: false
ContentType: application/xml
Content-Type: application/xml
Transfer-Encoding: chunked
Connection: keep-alive
Date: Sat, 09 Sep 2017 04:53:57 GMT
Server: AmazonS3
X-Cache: Error from cloudfront
Via: 1.1 f456a26d3c39946d9572c71344a45264.cloudfront.net (CloudFront)
X-Amz-Cf-Id: uMBNecP7OujcjbbHhWNxcHTLiC4ZGWMQLNHpGon1XsBdo-VXu2zNow==
There were also some others, but all of them were mostly about how I was forbidden from accessing Fusion 360.
After some closer looking, I found that the log said that Fusion 360 was (I think) missing some file(s):
Request:
GET https://cdn.web-platform.io/artifakt/release/v1.2.0/Artifakt Element Regular.svg
User-Agent: AutodeskDesktopApp/7.0.6.378 AutodeskWebServicesClient/7.3.10.1801 Windows/10.296
Referer: https://accounts.autodesk.com/authenticate/otp/7d69d65e-77aa-4050-a202-d9d746fcd4b1?viewmode=desktop...
Accept: */*
Accept-Language: en-US,en-US;q=0.5
Does this mean I should download this .svg file? If so I do not know the process. When I searched this .svg file, it showed me the document tree, and it was full of errors.
Ps. Am I forbidden because it still thinks I didn't accept the terms and conditions? I don't think this is the case because of the missing file(s), but I have no knowledge of advanced autodesk troubleshooting.
Please send help!
Solved by natasha.l. Go to Solution.
Hello @Anonymous,
I see a 202 error indicating a download issue.
Before downloading make sure you conduct the steps below:
Temporarily disable your pop-up blocker, Antivirus software & Firewall
Temporarily disable UAC on Windows 7 or Windows 10
If the error continues, take a look at this Fusion 360 Error Sign in Failure Due to Service outage, on how to rename the file to "LoginState.xml" to "LoginState.xml.BAK"
Let us know how it goes.
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Anonymous,
That's good to hear, the download must have been interrupted. Glad it was resolved simply & you are up & running.
Thank you for getting back to us, if for some reason you still believe the download was affected you should uninstall & reinstall.
Natasha
Helpful Links:
