Installs fail in Desktop App, message shown in app "The digital signature needed for this install can't be verified. Please contact customer support."
Solved by pendean. Go to Solution.
Hello @simon-h
Autodesk Desktop App checks the Digital signature for all the updates. Could you please mention the name of the update, so that we will test and contact the product team to fix the digital signature issue.
Srinivas.
hello@simon-h
Could you please mention the name of the updates, you tried to install and got the message"The digital signature needed for this install can't be verified. Please contact customer support."
Last time we got this message for navisworks and revit updates. Product team fixed the issue, it is not an ADA issue. ADA blocks the update if it doesn't have digital signature.
Please try this
Still you have problem, please try this,
Install latest ADA from here www.autodesk.com/ada-supportinstall
Srinivas
thanks it worked
@srinivasarao.potla wrote:hello@simon-h
- Uninstall ADA
Srinivas
