Autodesk Desktop App (Read-Only)
Welcome to the Autodesk Desktop App Forum. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
AUTODESK Update Errors
19 REPLIES 19
Message 1 of 20
CharlesJackson8339
1642 Views, 19 Replies
Have the following updates that fail, and cannot resolve:
AUTODESK Updates with unresolved installation errors:
1. 02-18-19: Infrastructure Parts Editor 2019.2 Update
Error: "Install Error 1603: Fatal error during installation."
Checked out "See More", tried some other tricks, nothing works, have updated to AutoCAD C3D 2020 since 2019 version when this started, but still get this update. Is this now an outdated update, and can it be deleted? If not, how do you get it to install? This update lingers on.
2. 11-04-19: Civil 3D 202.2 Update 64-Bit Update
Error: "There is an older version of this update already installed. Please remove the old version and try this installation again."
Typically, updates are to remove anything old automatically, then insatll te new update, however, since this appears to needs to be done manfully. Exactly how do you remove an old update?
19 REPLIES 19
Message 2 of 20
Hi@ CharlesJackson8339,
Thanks for your feedback.
i would like to know more about the issue. could you please send me the log files?
Please find the attachment for log file instructions.
Srinivas.
Message 3 of 20
Srinivas,
Attached is the log file.
Charles Jackson
Message 4 of 20
Hi@CharlesJackson8339,
Thanks for your reply. i couldn't find the attachment.
could you please attach the log files?
Srinivas.
Message 5 of 20
I'm getting the same error when trying to install the Autodesk Civil 3D 2020.2 Update. I've attached my log file.
Message 6 of 20
Hi@sniemeyer,
could you please send me the Autodesk desktop app log files?
Srinivas.
Message 7 of 20
I've gathered all the log files and have zipped them up.
Message 8 of 20
Hi@sniemeyer,
Thanks for the info.
I have checked the log files. Recently Civil 3D product team released an update but it has some critical issues and they expired that one and released new update with same name. so you already installed that expired update.  could you please uninstall civil3D 2020.2 update from control panel and then try the following things and then install civil3D 2020.2 update from Autodesk desktop app.
Exit Autodesk desktop app(from system tray menu)
Stop AdAppMgr Service(task manager)
%Programdata% > Autodesk > Delete the “SDS” folder
Restart Autodesk desktop app.
Example:
Please let me know if it works.
Srinivas.
Message 9 of 20
Srinivas,
I've reattached my log files.  Tried what you said in last post, and now will not go past initializing.
Message 10 of 20
Srinivas,
Got it to start downloading past initializing, but same 2 mentioned errors still occurred.   Another update (SHP...) did come in and it did download and install.  Also, forgot to mention the Autodesk Civil3D 2020.1 was not on my list to uninstall.
Message 11 of 20
in reply to: CharlesJackson8339
Hi, i've got the same problem : a merror message1.jpg i try the solution below and don't know to do next.
thank you for helping
Message 12 of 20
The Civil 3D update disappeared, never installed.  Infrastructure Parts Editor 2019.2 still there, and still not working.  Can we make that disappear too!
Message 13 of 20
srinivasarao.potla
Hi@educad.tlm,
you already installed the update.
Could you please try this, it will disappear from Autodesk desktop app?
Srinivas.
Message 14 of 20
in reply to: srinivasarao.potla
hi srinivas,
unfortunately the desktop app manager show me this on screen, and no stop.
Message 15 of 20
srinivasarao.potla
Hi@educad.tlm,
Thanks for letting me, its working fine.
Srinivas.
Message 16 of 20
That worked. Thanks.
Message 17 of 20
The original issue is unresolved.
Message 18 of 20
Civil 3D 2020.2 Update 64-Bit Update finally installed with a regedit drive designation fix, but the 02-18-19: Infrastructure Parts Editor 2019.2 Update that never installed still lingers on.  How can I remove from the update list, as it is probably outdated.
Message 19 of 20
3Ds Max 2023 installation
Installation incomplete. (error code: 1603)
Catie D
Tags (1)
Message 20 of 20
pendean
in reply to: bubblesdoa
Technology Administrators
