Autodesk Desktop App problem
husamcivil
husamcivil
Hi all
I have revit 2018.3 when I check update in Autodesk Desktop App the error massage  will appear
I try in revit 2019 also I have same problem for several day and several try
note: error massage attached
DarrenP
nothing is attached
DarrenP
husamcivil
error massage
srinivasarao.potla
Hi@husamcivil,
Thanks for your feedback.
I haven't see the Revit 2018.3 update on Autodesk desktop app attachment.
I would like to know more about the issue. could you please send me log files?
Please find the attachment for log file instructions.
Please try this.
            Exit Autodesk desktop app(from system tray menu)
           Stop AdAppMgr Service(task manager)
           %Programdata% > Autodesk > Delete the “SDS” folder
            Restart Autodesk desktop app.
Still if you see the issue, please try this also.
  Uninstall autodesk dekstop app
  Install  autodesk dekstop app fro here : https://www.autodesk.com/desktop-app
Please let me know if it works.
Srinivas.
kristofer.barros
Hi Husam,
Please try this solution:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Autodesk-Desktop-App-err...
I think your Desktop application is not up to date so it cannot connect to the server.
Kristofer
