Does my driver have to update?
Solved by pendean. Go to Solution.
the hardware support team did everything and its still doing it. It have to be autocad application it gives a video tdr failure.
@rasabobo you need a new computer if you already replaced your RAM and/or Motherboard and/or your video card, there is no software solution to fix a bluescreen hardware failure. Sorry.
BUT... if you wish to continue with your thoughts then I suggest you open a support case with Autodesk directly if you are on subscription to seek out Autodesk Support's help:
https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options/we...
If this is an EDU license... EDU Support Access is here, look for the new automated pop-up with common questions
https://www.autodesk.com/education/support?startHelpBranch=AVA-edu-flow&mode=open&_ga=2.35539169.196...
and here https://forums.autodesk.com/t5/installation-licensing/education-license-renewal-lacks-renew-option-o...
