Product Design & Manufacturing Collection consumes Flex Tokens
There seems to be an issue with the D&M Collection and Flex Tokens.  If a user has access to a dedicated seat for D&M and no access to Flex Tokens, tokens can still be consumed.  Fusion 360 is the culprit.  Within Fusion 360, there are many addons like Generative Design.  When you assign the D&M Collection to a user, Fusion 360 is a product you can use but as a default, Generative Design, etc are token based addons.  They are checked so they will consume tokens when a user is not granted Flex Token access.   I have included the image below.  These option should only be available in Flex Tokens and should not be included in D&M.
This brings up a few concerns:
  1. The reason the users have D&M and not flex is that they shouldn’t be accessing tokens at all.  But this these being selected as optional features, then any user with D&M can consume flex.  Should these be turned off as a default instead of checked?
  2. It simple to uncheck these so the users cannot consume flex when in Fusion 360 for a handful of seats but when we look at the case below, 72 seats or an even larger scale client with 200-300 seats, manually unchecking each user is time consuming and not ideal.  Is this something we can get as an improvement in the future where they can opt out of flex in collection all together?  Perhaps keep these options in token assignment only for hybrid users.
  3. Although the user has an in-application prompt notifying them the fusion 360 addons will consume Flex tokens, the user may not understand or are aware of what tokens are to make the sound decision and accept the usage of the flex tokens for the addon.  This should be something that the user needs to discuss with the administrator and be granted access.
I think this is something that could lead into a bigger issue and needs to be addressed sooner than later
3 Comments
lynda.laramee
Community Visitor
This should be a priority.
sbrowne
Jacky:
This issue seems related to the issue that I just posted.
Flex Token Usage Notification - Autodesk Community
You say that "Fusion 360 ... will consume tokens when a user is not granted Flex Token access."  Am I interpreting this correctly?  If I assign a user to be able to use Flex Tokens they will automatically consume Fusion Tokens even if they are not actively using it?
(My issue above was also with Fusion.)
Did you ever get anyone at Autodesk to address the consuming tokens issue?
Jacky.huynh
No that is a different issue.  Within the Fusion 360 program, they have addon like Generative Design that are extra paid functionalities.  These addons will consume extra tokens if you decide to use them.
Administrator Productivity
