AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Updates for removed software
nuno_wallnut
Message 1 of 15
nuno_wallnut
I have had this issue for some time but now im investing some time to solve it.
Autodesk access shows available updates for software that is no longer installed. I have followed directions for removing the registry keys, used windows troubleshooter and still i got the same list of software updates for uninstalled products.
There was one thread to clear cache by deleting a folder in the appdata, but, i think it was for the autodesk desktop app. There is not folder with the same name anymore.
Is it possible to solve without uninstalling everything and how?
Replies (14)
Message 2 of 15
Simon_Weel
Autodesk Access isn't of much use at the moment, IMO. So either ignore or uninstall Access. You're better off checking your Autodesk Account for updates every once in a while?
Message 3 of 15
pendean
Community Legend
Community Legend
If you are married to only using the Autodesk ACCESS tool, you'll want to get in the habit of downloading the latest version manually yourself monthly or quarterly from the website before you use it (restarting your PC afterwards is always recommended). It is a work in progress and they have opted into a very odd "limited release" update method where not all of us get the latest version automatically at the moment of release, so there is that reality to contend with.
OR... as @Simon_Weel noted, when you think you have an issue with your software that a restart of the PC does not resolve, or on a quarterly schedule, login here and check for software updates to install
https://manage.autodesk.com/products/updates
Message 4 of 15
Simon_Weel
.... and they have opted into a very odd "limited release" update method where not all of us get the latest version...
This sounds a lot like Microsoft updates for Windows? You never know what you gonna get and when you gonna get it. Let's hope Autodesk doesn't adopt the Microsoft quality assurance, where the first machines getting an update also act as beta testers....
Message 5 of 15
danny.polkinhorn
Autodesk Support
Autodesk Support
@nuno_wallnut , can you be more specific about what is uninstalled, but Access is showing updates for?  If one of those is AutoCAD 2023, check this article.  https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Autodesk-Access-sh...
Danny Polkinhorn
Sr. Product Manager
Message 6 of 15
nuno_wallnut
You make very good points. I was not aware of the "state of the art" for autodesk distributions. This was all very usefull information.
About the products, they are 3D Plant and Autocad MEP, but have been uninstalled over one year ago. Its just anoying. I think im going to "divorce" Autodesk Access and recomend my coleagues about the same solution. Thank you all.
Message 7 of 15
pendean
Community Legend
Community Legend
@nuno_wallnut wrote:
...I think im going to "divorce" Autodesk Access and recomend my coleagues about the same solution. Thank you all....
Best thing we ever did in our offices 🙂
Message 8 of 15
danny.polkinhorn
Autodesk Support
Autodesk Support
It's an incorrect assumption that you need to be on the latest version of Access.  We release new versions on a monthly basis, and sometimes we skip a month if we want more time.  I think you'll find that monthly is a fairly modern approach for a desktop product.  If there is a critical update that you need, we will push it out to all users, as we have done in the last month with 2.6.
As for its usability in your environment, that's a personal choice which you are free to make, but it is not applicable to everyone.  We're seeing quite good adoption rates, and users are 4 times more likely to install an update via Access than downloading from Account.  You are by far in the minority of users with issues.
This particular issue is one that we are aware of related to an older installer at the time it was uninstalled, unrelated to Access itself, and we are being cautious about touching registry entries (as noted in the article above).  @nuno_wallnut if you can collect the logs for us and send them to me, I will take a look and provide instructions on the registry entries to remove.
Danny Polkinhorn
Sr. Product Manager
Message 9 of 15
pkenewell6347
Hi Danny,
I'm having the same problem with Access. Even though I have had "AutoCAD Mechanical 2022" uninstalled for a couple years now. An update for it keeps popping up in Autodesk Access. I have tried to manually delete the "UPI2" entries that still had AutoCAD Mechanical 2022, and reboot, but the problem still persists. I have the logs collected and can send to you privately if you are willing to look.
Message 10 of 15
pendean
Community Legend
Community Legend
@pkenewell6347 You will need to download and install the latest version of Autodesk Access (then restart your PC) for the issue to go away
https://www.autodesk.com/products/autodesk-access/overview
OR... turn off ACCESS altogether and enjoy never getting prompted.
Message 11 of 15
danny.polkinhorn
Autodesk Support
Autodesk Support
Hi Phillip, thanks for your help.  Collecting the logs and submitting them is how we address these issues.  If you can email them to me, that will work, or if you want to post them in your file share of choice, then send me a link to my email, that's also ok.  firstname.lastname@autodesk.com
Danny Polkinhorn
Sr. Product Manager
Message 12 of 15
pkenewell6347
@pendean I already have the latest Autodesk Access installed, rebooted, and the problem still persists.
Message 13 of 15
pkenewell6347
@danny.polkinhorn I sent you a link to a SharePoint folder with the Log files. Please let me know if you need anything else.
Message 14 of 15
pkenewell6347
@danny.polkinhorn  Well - might be False Alarm now, After a 2nd reboot on Friday. the offending update finally disappeared! Looks like the keys I removed from the Registry finally worked. I will keep and eye on it and let you know if it pops up again.
Thanks and sorry to waste your time.
Message 15 of 15
tomengel
Having the same issue for some time now. I've attached the logfiles and a screenshot of Access showing 2 apps that are no longer installed
