Autodesk Access
Autodesk Access
whitebirchstudios
Autodesk Access
whitebirchstudios
I have Autodesk Access installed, I am logged in, but it isn't giving me any updates. My MAX 2023 is at "MAX Olympus", which is the original version release.
pendean
Community Legend
Community Legend
@whitebirchstudios Double-check availability of that here too (and install it if you wish)
https://manage.autodesk.com/products/updates
whitebirchstudios
Yes, thanks, but that isn't the issue. Autodesk Access isn't working.
fergal_adsk
Hi @whitebirchstudios  , If you able to collect the log files for your machine and log a Case, our support team can help solve the problem for you. https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-Use-the-Log...
Simon_Weel
That's the problem. If you read some posts in this forum, you'll notice you're not alone. It's 'work in progress' so better not rely on it. Just check your Autodesk Account page regularly for updates.
