Communauté
AutoCAD – tous produits - Français
Bienvenue sur les forums AutoCAD d’Autodesk. Partagez vos connaissances, posez des questions, et explorez les sujets AutoCAD populaires.
annuler
Affichage des résultats de
Afficher  uniquement  | Rechercher plutôt
Vouliez-vous dire :
snap probleme
6 RÉPONSES 6
RÉSOLU
Répondre
Message 1 sur 7
507 Visites, 6 Réponses
snap probleme
Bonjour,
lorsque je sélectionne une ligne, les <snap> apparaissent. (good)
Mais soudainement, je ne suis pas capable de bouger aucun des <snap>. Pourquoi ?
Merci
6 RÉPONSES 6
Message 2 sur 7
pendean
en réponse à: Anonymous
LT version?
Windows version?
Is this a sudden new problem? Or a problem that only exists in one file?
Message 3 sur 7
That’s the answers of your questions:
LT version? 2017 (en essaie)
Windows version? Windows 10
The problem is only in one file. The “snap point” doesn’t respond, it
remains inert.
Best regards
Salutation!
René Roy
1755 rue De Toulouse,
Sherbrooke, Qc, J1J3V6
Tél: 819-565-7257, royr05@bell.net
Message 4 sur 7
Emmsleys
HI @Anonymous,
If you could please provide more information so that I can get a better idea of what your issue is.
Has this been an ongoing issue? or new issue?
If you log in as a different windows user do you have the same issue?
You can also create a screencast video to help give us an idea of what your issue is along with the additional information.
Sarah Emmsley
Technical Support Specialist
Message 5 sur 7
pendean
If the problem is one single file: INSERT the problem file into a good working empty file, EXPLODE, SAVEAS and test to see if you can repeat the problem.
Message 6 sur 7
Emmsleys
Following up on this thread, I haven't heard back if you were able to try the suggested steps.
Please post back in the thread if you are still having an issue with AutoCAD the community and myself will be more than happy to help.
Sarah Emmsley
Message 7 sur 7
thank you but, my problem is resolved
best regards.
Salutation!
René Roy
Vous n'avez pas trouvé ce que vous recherchiez ? Posez une question à la communauté ou partagez vos connaissances.
Publier dans les forums
