Que tal: estaba usando autocad version 2015, por error teclee AA, y me borro algunos tipos de escala y otros atributos de unos dibujos. segun la ayuda del propio programa son atributos; segun la ayuda de la pagina es el comando AREA; segun el foro no existe...
que es y que hace ese comando, anexo captura de pantalla.
Gracias.
@Anonymous para una mayor claridad @joaquim.moral ha editado el título original: Comando AA?
Recuerda consultar cómo escoger el mejor título para tu post. ¡Gracias por participar!
¡Resuelto! Ir a solución.
Resuelto por bc.chiquito. Ir a solución.
Open your acad.pgp and look for AA command
If it's not in there, then you must have an autolisp or .arx running to purge the anno scale.
If you're using regular AutoCAD, you must have a custom-defined AA command that does those things. It could be something that is loaded for you automatically. The first thing to try is to look for the common way of doing that -- at the command line, put in:
(findfile "acaddoc.lsp")
If that returns a file path with the file name, open that file in a plain-text editor such as Notepad. If there is a line in that file that starts with:
(defun C:AA
[not case-sensitive] then that is the definition. If you don't want that command, it can be removed [we can show you how].
If (findfile) doesn't find a file by that name, or if the file is there but it doesn't have a definition for AA, start APPLOAD and check whether there's something here:
If that doesn't list anything that contains a definition for AA, try:
(findfile "acad.lsp")
in the same way as for acaddoc.lsp.
If none of those finds anything, and you haven't APPLOADed something from somewhere else, I'm not sure where else to look.
Patchy, Kent1Cooper:
Hice ambas soluciones, lo probre en unequipo con autocad de instalación limpia, ya que el mio si tengo configuraciones y a lisp cargados.
Hace la misma rutina, borra o purga las escalas.
Agradezco las respuestas.
Hola @Anonymous,
gracias por tu respuesta.
Restamos a la espera de que nos cuentes cómo te ha ido, y si las respuestas te han ayudado.
Si es así, puedes hacer clic en el botón "Aceptar como solución". De esta manera ayudas a que otras personas usuarias puedan acceder y encontrar más fácilmente la información.
De lo contrario, coméntanos en este mismo hilo en qué punto te has quedado para que la comunidad pueda seguir ayudándote.
Gracias y esperamos tu respuesta,
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Your question got successfully answered? Then just click on the 'Mark as solution'
Joaquim Moral
Spanish Community
Hola, @Anonymous
Como te han mencionado, el comando AA activa la herramienta de área, seguramente tenes personalizado este comando o un lisp corriendo haciendo algo raro.
Ve Manage>Customization> Edit Aliases y se abrirá en el archivo autocad.pgp, revisa qué está activo para el comando AA, también revisa los lisp que hayas instalado recientemente.
Sería difícil deducir qué se activo en tu equipo, intenta recuperar el último archivo .back y ver si las escalas siguen en ese respaldo convirtiéndolo a .dwg, o abre otro archivo que las contenga.
Ahora, vamos a llevar estas escalas al archivo que las perdió, en el archivo que si tiene todas las escalas:
Será importante que detectes que tiene modificado o que hagas una desinstalación limpia y reinstales con la configuración por defecto, si no logras detectar qué cambió el comando.
Espero que te sea útil. Saludos.
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
